Sharp copier ar6020 error codes ch plinking
SOURCE: sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly
installed
For the 'CH' check the covers and make
sure all covers are closed properly.
For the 'Blinking CH' take the dev.
Unit open and the reinstall unit properly.
Pls rate – thank you
SOURCE: Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
SOURCE: Sharp Copier 2025 error steady CH
I believe that that error code relates to the dorter. Make sure it is seated correctly against the copier.
SOURCE: Our Sharp AR-N275 copier is displaying error code
Hello sir; CH it means somewhere the door is open, check it out all the door inside and outside.
SOURCE: error code ch
CH mean any kinds of door is open or not close properly.Please close door properly.right side or front side.it has a connector switch it is open or displace.
