Question about Citizen Watches
I PURCHASED AN OSHEN AD 1209 WHICH IS DEFECTIVE CANNOT SET AT ALL WOULD YOU PLEASE REPLACE THIS ONE
THE WATCH JUST STOPPED WORKING TRIED TO HAVE IT FIXED TO NO AVAIL I LIKE THE WATCH BUT I HAVE NO WAY OF KNOWING WHAT TIME IT IS I AM A DISABLED SENIOR CITIZEN WITHOUT THE WATCH I AM NOT ABLE TO GO OUT PLEASE TRY TO REPLACE THIS ONE I WOULD SEND IT BACK TO YOU FOR A REPLACEMENT THANK YOU HERB
    Genius:
  • 1,691 Answers
This is only a public tech help site. You would have to send the watch to Citizen if it is defective inside of the module. The local watch store will not be able to fix it. Citizen can fix any of their products.
Posted on Feb 11, 2018
6ya staff
SOURCE:
Anonymous
  • 73 Answers
SOURCE: Setting the time on a Citizen Eco-Drive Watch
Go to this link and pay particular instructions on how to find your watches movement or caliber number.
http://www.citizenwatch.com/COA/English/settings.asp
Posted on Dec 31, 2007
Anonymous
SOURCE: Citizen Promaster Blue Angel Navihawk - JN0040-58L
I have seen a website with full review by someone from Adelaide.
If you Google C300 Citizen it should be easy to find.
From what i read there is no proper solution but he has suggestions
Posted on Mar 11, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: setting time on my citizen eco drive skyhawk model jr3090-58l
Go to this site and choose interactive settings for your watch:
http://www.citizenwatch.com/COA/English/find.asp
Do not forget to rate, please.
Posted on Jan 19, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: set the time on a 1400 sports watch
Follow this link and find maual:
http://assets.timex.com/manuals/?timexBrand=core
As you did not submit full details of your watch I can give this link only.
Rate me, please.
Posted on Mar 15, 2009
Anonymous
SOURCE: cant se time Citizen 8988-q02047 HSB wristwatch
In the time mode, press the upper right button for 2 seconds and the time display will flash. Then press the same button untill the entire time will flash, or both hour and minutes flash at same time. When the hour and minutes flash at same time, this adjust mode is the adjusting of the analog left display (A1). Now, press the lower button for adjusting de hour shown at the digital display that shows the same hour at analog display. This method is to adjusting the 8982 that is the "father" of 8988. Like a Citizen collector, and don´t know any website that you can view the setting instruction of 8988, only the 8982 is disposable here: http://www.citizenwatch.com/downloads/techguides/8982.pdf
Posted on Aug 11, 2009
What can I do, just purchased a watch and is not working properly.
Honestly if it were me, I would simply return it to where it was purchased.
Also know that anything purchased via a credit card is usually protected.
You can call the credit card company and tell them the item is defective. They will ask if you have tried to remedy the situation with the seller, and go from there.
I hope you get your refund. God Bless and Thank you and your husband for your service.
Nov 13, 2014 | Watches
Oshen ad0721 analog frozen. Digital works fine
Hi
The Ana/Digi watches have 2 different batteries to run each system individually..
So you need to replace battery of the Analog one..in fact I recommend to replace both at the same time..
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Oct 07, 2011 | Watches
I recently purchased an Invicta Outdoor Trail Edition Men's watch, model J401668. The manual states to pull the stem out to the first click and rotate it counterclockwise to set the day. It does not...
You're probably pulling it out to hard. Solution: pull the stem out completely and carefully try to push it back in for one click only, then attempt to set the date. If this doesn't work, return the watch as it is defective.
Jun 09, 2011 | Invicta Watches
The second hand will not re-set to zero. It has stopped. The watch works perfectly during the day apart from the second hand not moving, but , the watch stops at 11.15 at night. When I get up in the...
This is a symptom of what is usually several possible issues:
1) The most common is that the battery must be changed. Insist on Energizer batteries only (as they do not leak) and visit your local Certified Master Horologist for assistance in changing the battery and resetting the watch.
2) The movement must be serviced every 3-5 years by a qualified professional. Dust and debris can cause the symptom of stopping and starting the movement. If you have owned it for less time than this, remember that the watch may have been manufactured and in the retail location longer than this period of time before it was purchased.
3) The movement is defective or damaged. If the watch is under warranty, and it was purchased through an authorized dealer, Armani will take care of this issue for you at no charge.
To properly assess this issue, I recommend taking the first step, as a CMH also has the proper tools to test the movement and battery to determine the best next course of action.
watchandpen
Feb 25, 2011 | Giorgio Armani Emporio Armani watches...
I just bought this watch Nautica A31504 and it does not seem that any of the chrono buttons work. Is it the watch that is defective, or am I doing something wrong. In the manual, it says that I can...
The watch has been displayed for long time. You have to replace new battery for the watch and then those functions will work again. Good luck! :)
Feb 10, 2011 | Nautica A31504 Watch
New Invicta Men's Diving Watch--stops working after I set it the first time. I set it again,it works for awhile then stops again.Help
The problem you are describing is in the electronic timing module and there is nothing you can do but return it to the place of purchase for exchange.
Jan 13, 2011 | Invicta Watches
I need an instruction manual for an OHSEN Watch model number AD0930
Google OSHEN watches and go to World of sport watches look up your style of watch and they have the manual there hope that helps.
Jan 02, 2011 | Watches
Watches Logo
Top Citizen Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Felipe Valera...
Level 1 Expert
Are you a Citizen Watch Expert? Answer questions, earn points and help others
