Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
ali ahmad Posted on Aug 29, 2015
Sony wega tv not save all chennal and sound - Sony FD Trinitron WEGA KV-32FS120 32" TV
4 Related Answers
Anonymous
  • Posted on May 24, 2009
SOURCE: NO SOUND AUDIO
Just to be sure, it isn't on SAP is it?
That would be under the MTS/SAP button.
If that's not it, are there any other distinguishing features that you notice?- A buzzing or a clicking or peculiar light flashing?
I wouldn't be able to help with that, but the next person might!
shaun taylor
  • 1527 Answers
  • Posted on Nov 10, 2009
SOURCE: replaced lamp in Sony Wega tv - Sony xl-2400. tv
hello make sure the lamp and the cover is fitted securely, when you've done this the tv should be ok
shaun
Anonymous
  • Posted on Nov 25, 2010
SOURCE: my tv is kv-tg21l70 my sony
Were going through the same thing the problem might be that you might need to replace your bulb if thats not it you have to unplug the tv open up the front of the screen and clean off all the dust were doing it again tomorrow... DO NOT USE WINDEX OR ANYTHING WITH ALCOHOL!!!!! USE A PRODUCT MADE FOR CLEANING TVS... You can pick it up at walmart along with a can of air that is alcohol free it cost no more then 9 dollars total... or any electronic store. 15 min and your done. Remember DO NOT USE AYTHING WITH ALCOHOL IN IT!!! Good Luck!!!
Anonymous
  • 195 Answers
  • Posted on Dec 07, 2011
SOURCE: how do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking li
Good day!!!
6 blinks its the clear indication that you have bad power supply board..
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
How can change sony wega tv sound system from bg to dk/
Refer its user manual for details. You can select the system by entering its menu [sound]. Electro help
I have a 32" Sony Wega Flat Screen TV. Currently
Check out this article: http://www.ehow.com/how_8256946_fix-sony-32-trinitron-picture.html
It goes pretty in depth in how to troubleshoot problems with your Trinitron TV. Hope this helps.
2helpful
Kv 27ts27 set works fine except lost color. now black and white
pls check and selact in your tv colour system PAL / NTSC / AUTO
set Auto colour system is Best .
set chennal Auto serch
if not
then problum is in side tv pcb. so repare pcb with nr. thech.
Red light blinking 7 times on Sony Triniton Wega TV
This means one of three things, either the lamp is bad on your tv, the ballast that powers the lamp is bad or the safety switch for the lamp door is not depressed or it has come un-plugged. It could also mean the power supply or fuse on the power board is blown. I am assuming this is a DLP tv, and if so, it is fairly easy to fix it or find parts for it online. If you are slightly mechanically inclined, want to save money and dont mind paying attention to detail then you can fix it yourself. If you need help dont hesitate to ask.
Multi color stripes on 60 inch sony wega, no picture
it sounds like the projection unit went out. if it is still under waranty then i would take back and get it fixed for free. if anything i would contact sony and tell them what is wrong with the tv.
2helpful
3answers
FV-27KV300 WEGA 27" Sound Problem
adjust the sound IF in the tuner or in the IFblock
Sony wega reduced sound
the problem maybe is in the sound IC. try to re solder the sound section of the TV.
2answers
Tv sound but no picture
Hello, please count how many times the lamp blink. Best regards, Arpi
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
