Question about Contixo Kids 7-inch Tablet Touch Screen Android 4.1 Dual-Cameras Wifi Blue
I can't get the tablet to power off or on. I have the screen that shows the battery is dead, and not charging
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 19 Answers
Battery is probably dead u may need to either replace the charger or tighten the end of yours with pliers to ensure tight fit to port in tablet
Posted on Aug 29, 2015
6ya staff
SOURCE:
My proline tablet H71930i will not charge or be turned off. The indicator that the battery needs recharge when off does not show....please help it worked this morning but now it's dead.
do a hard reset and then make sure the software is up todate. 1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
Jan 15, 2018 | Tablets & eReaders
I have a brand new amazon fire 7 and am trying to set it up. First how can I see how much my tablet is powered up? And how do I connect this device to my internet?
Charge it. Press and hold the power button. If shows a battery by itself it's dead and it's not charging. If it's a battery with a lightning bolt symbol it's dead and it's charging. If it turns on, go to settings, find wifi settings, turn wifi on, find your wifi network, and enter the password for your wifi.
Aug 25, 2017 | Amazon Tablets & eReaders
NOTHING BUT A BATTERY AND RCA TABLET COMES ON WITH CHARGER BUT SHOWS NOTHING BUT A BATTERY ON SCREEN RCA 7 INCH TABLET
With the charger hooked up and plugged in the tablet will only show the battery on the screen briefly to let you know it's charging. It won't actually boot up until it has a sufficient charge. Just let it set that way for a couple of hours then try to power up.
Feb 26, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
How do I get my tablet to turn on without plugging it in?
Sounds like the battery is dead, what does the Battery Charge indicator show, and will it stay on if you remove the charging lead?
A Factory Reset might cure this if the battery is showing fully charged with the power lead removed.
Nov 23, 2014 | Tablets & eReaders
Why wont my Samsung Galaxy Tab on 3 Mobile Tablet PC charge
either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
Aug 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Why will my changer not make a good connection
The charger is working. Your Battery won't take a charge. Does the tablet work when it is plugged in? If so, your battery is not holding a charge anymore. Low budget tablets are famous for this. My daughter has had two that are dead. Both a little over a year old. You can take it to the Microsoft store and see if they have another charger and see if it charges. Otherwise it's the battery.
Jul 18, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
My tablet won't power, only shows battey then shuts off, won't charge
Most likely a dead battery or bad charger. Test and/or replace the battery or charger.
May 10, 2014 | Noria 7 Android 4.2 Tablet - White
The battery on my Hisense table with not charge.
Your battery could be dead or the charging port has gone bad. Also try a different charger.
May 09, 2014 | Tablets & eReaders
Tablet froze and now doesnt restart
Leave your tablet charging for a hour minimum. The battery might be so dead it has no power to start up at all. You get in to recovery mode do restore to factory settings.
Jun 02, 2013 | Coby Kyros 716829701508 Tablet PC
When I try to charge my samsung galaxy tablet a yellow triangle pops up on the battery sign
I had this same thing. The Batter image had a red line on the right side and the yellow triangle had an explanation point in the middle.
I searched the net and found a few solutions.
1. Hold the power button down for 30 seconds.
2. Hold the power button down and the volume down button at the same time for 30 seconds.
3. Just let it charge and over night and it should go back to normal.
I did all 3, in the order I wrote them. While in step 3, after about 5 minutes I pressed the power button and it showed that it was charging normal.
Hope this helps.
Dec 04, 2012 | Samsung Galaxy Tab Tablet PC
Contixo Kids 7-inch Tablet Touch Screen Android 4.1 Dual-Cameras Wifi Blue Logo
277 people viewed this question
Top Contixo Tablets & eReaders Experts
Vernon Taylor
NOEL
NOEL
john h
Are you a Contixo Tablet and eReader Expert? Answer questions, earn points and help others
