E00 usually requires a technician to reset, although you may manually do it by pressing and hold the start button for five seconds the "feature" should disable. E21 is blocked filter or excess of fabric in the filter over time. Turn the appliance off by the main supply, access the filter located on the bottom kick plate. Remove the filter and clean in hot soapy water, check the propeller for fabric debris. Run a hot wash without any clothing 70C or above with 1/4 cup white vinegar, you should do a maintenance wash at least every month and clean and remove the powder draw or detergent draw and inside every 2 weeks, clean the rubber door seal remove coins which are common and build up of debris
The E00 code on your SAM4S cash register indicates a Sequence Error.
You can try an Initial Clear to reset the error:
1. Turn the power switch located on the right side of the register to the OFF position. 2. Turn the control lock to the P position. 3. Press and hold the key position where the SBTL key is located on the default keyboard layout. 4. While continuing to hold the SBTL key, turn the power switch to the ON position. 5. The message "INITIAL CLEAR OK!" prints when the initial clear is complete.
You may have to try the Initial Clear procedure a few times to clear the E00 error.
On an Electrolux washer the error code "E00" stands for No code stored. This could be a miscommunication I would recommend you perform a reset on your washer. You can do this by flipping the household breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E00". I look forward to assisting you. -Matt
If you are getting error code E00, it usually indicates that your washer is experiencing a generic error. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code
E00 Means the red magnetic key (the one on the string) is not inserted.. If it is then the magnetic switch may be faulty.
E01 Is an electrical fault - the wire that runs inside the frame is probably crushed while assembling
E02 Means the motor is not running - either burnt out, stuck or the optic device is not functioning correctly.
This are what I found out by trial and error - hope its useful to someone - I'm looking for a copy of the manual for this thread-mill if anyone could send me a scan or photos of the pages - thanks very much.
You may have a corrupted ccu or relay. Does the machine drain and is there an error code? It starts ok and then does not continue and the pressure switch is ok? You may want to remove the swith and lightly blow into it and check for continuity and then ohms. Any small measure and I would replace it. Also if the ccu says it is ok and it is not then I would question the ccus ability to function normally.
