Samsung HT-E4500 5.1 Channel Blu-ray Home Theater System Logo
Yvon Barrette Posted on Aug 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove firmware or cinavia? - Samsung HT-E4500 5.1 Channel Blu-ray Home Theater System
Kristine
Level 2:
Sergeant:
  • Samsung Expert 294 Answers
  • Posted on Feb 15, 2020
Kristine
Samsung Expert
Level 2:
Sergeant:
Answers
294
Questions
0
Helped
171747
Points
904
You can try Leawo Blu-ray Cinavia Removal. is capable of permanently removing Cinavia protection with high speed, as well as 1:1 copying Cinavia-free Blur-ay disc.
You can check on this tutorial for more options and how to remove the Cinavia protection:
5 Best Cinavia Removal Software Tools for You
Audrey Messer
Level 2:
Sergeant:
  • Expert 182 Answers
  • Posted on Aug 24, 2015
Audrey Messer
Expert
Level 2:
Sergeant:
Answers
182
Questions
10
Helped
46424
Points
588
Can you give a little bit more info on this: Is it that you are having problems with viewing discs because of watermarks?? Or have you updated your firmware and it is causing problems? Here is a link to where you can download your manual if you don't have it: http://www.samsung.com/us/support/owners/product/HT-E4500/ZA
How do i remove the Cinavia code 3 from my PlayStation 4
If you are using PlayStation and then you come across Cinavia Message Code 3, you can go to Settings >> date and time settings, then set the date and year one by one to fix it. But after setting, the Cinavia Message Code 3 will appear minutes later.
Another way to solve the Cinavia Message Code 3 is to use a Cinavia removal to remove the protection. You can try Leawo Blu-ray Cinavia Removal
3answers
How Do I Bypass Cinavia On My samsung home theater blu-ray player?
I have a Samsung HT w/bluray, but I don't know what "cinavia" is. Sorry!
2answers
How do u fix ur Playstation from being muted code 3.
The issue is that you have updated the firmware and Sony has implemented Cinavia Protection that causes the unit to auto-mute. I found a URL that explains a temporary work-around but I would either try to go back to a previous build(primarily one that did NOT give you this issue) or wait for Sony to release a fix for this Cinavia Protection program. I am sure there are game hackers that will come up with a plug-in or a fix for it but would be best to wait for Sony stamped fix before I would do anything.
Hope this helps. How to Get Rid of Cinavia Protection on PS3 Or at Least Bypass it
2answers
How do I remove Cinavia?
Cinavia is an anti-piracy watermark put onto movies and such. If it pops up on your disc then it's probably a pirate copy.
2answers
I have a LG blue ray player with cinavia message code3 how do i get rid of it
When you receive Cinavia Message Code 3, then it means that the audio track of your Blu-ray or DVD content contains Cinavia code. One of the solve the Cinavia Message Code 3 is to use a Cinavia removal to remove the protection. You can try Leawo Blu-ray Cinavia Removal.
1helpful
2answers
Cinavia message code 3
Didnt work is there way thatmight work
3helpful
2answers
Samsung HT-F5550 and cinavia audio problem any solution plase
help my player blu ray its get cinavia code message 3
1helpful
2answers
I have some movies downloaded to an external hard drive. When I try playing them through my Samsung HT-D4500 or HT-E4500, I get an error message: Cinavia Message Code 3, and the sound is muted. This keeps...
The cinavia is not an error. This means that Samsung suscpects that you dont have the proper licences to play that file.
Cinavia is a copy protection that is used in some Blueray movies, and this copy protection is not removed when the file is ripped from the BD disk.
If you play the file on a computer or some other media player that dont have cinavia protection enabled, then the file will play without problems.
I have a Samsung HT-D6750W, and the same problem apeared after a firmware update, think it happended between fw version 1012 and 1013.
There is no way to downgrade the firmware in these players, but some of them does support custom built firmware. After you get that custom firmware installed, the software will be more open. Then it will be possible to patch the needed files to bypass the cinavia.
But this is a complicated process which require a bit knowledge to linux. And doing stuff like that will involve a certain risk of bricking the device if you do it wrong, and it will certainly break any warranty.
But if you are still feeling comfortable with trying this, then go to the SamyGO and try to figure out if your model is supported or not. Here are a few links to help you get started. But before joining the forum and start asking questions, do read all the info in the wiki's and search for your questions in earlier posts first.
http://wiki.samygo.tv
http://wiki.samygo.tv/index.php5/Patched_firmware
http://wiki.samygo.tv/index.php5/ExeDSP_modifications
2answers
How to bypass cinavia on LG blu ray player
I have LG BP250 BLU RAY PLAYER and I'm having problem with Cinavia message code 3. Please help
1helpful
2answers
How to fix cinevia on Lg blu ray bh4120s
please help! ive update my LG BH4120S bluray home theater, and now i got de cinavia problem. where can i get an old firmware??? thanks
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
