I've tried resetting display mode by holding both fast freeze and fast cool. Also reset ice maker. the temperatures on both are not coming down even though i've manually reset them both. thankyou
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE
A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:
http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
REMEMBER GOD IS THE REASON FOR GOOD ADVICE"
Refrigerator Is Not Cooling What To Check And How To Fix
SOURCE: refrigerator will not cool
no there a is nothing you can do, they gonna change a card, and charge for the card and the job,now check for waranties maybe the card is on waranty...good luck
SOURCE: SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
SOURCE: fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
SOURCE: Samsung double door refrigerator/freezer is not
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
SOURCE: samsung SRS583HDP fridge not cooling. Side by side
Most likely the thermostat in the fridge, especially if it read 5 degrees until you reset it. Possibly the compressor in the fridge side as this fridge has twin cooling, or the circulating fan in the back of the fridge is frozen, which is a common problem as well.
Easiest things to try is to see if the fan is frozen and check if the fridge cooling is actually working. Turn off the fridge, remove the shelves, remove the 4 screws that hold in the bottom cover and the 2 screws that hold the water tank in. Cover should then come out a few inches. Reach behind and unplug the 2 plugs and pull out the cover. If the cover doesnt come out easily it may be glued to the back of the fridge by ice. Leave for a couple of hours and gently prize it off. Check for ice around the fan and that the fan spins freely. You could try sitting the cover inside the fridge, plug it in turn it back on for a few minutes (be careful) and then open the door and quickly look / listen to see if the fan is still spinning (it stops when you open the door). Leave the fridge off for a while until the ice disappears off the coils. Turn back on for half an hour. The coils should be icy again. Anything else call Samsung. If the deal in your country is the same as mine the fridge has a 2 year warranty but in the fine print the sealed compressor unit has five years on parts only. You could get the unit replaced for labour costs only. Check your warranty card.
