Bunn 10 Cup Home Coffee Brewer Logo
M
Mike Kargle Posted on Aug 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Very loud when heating - Bunn 10 Cup Home Coffee Brewer
jasbo
Level 3:
  • Bunn Master 2,239 Answers
  • Posted on Oct 30, 2015
jasbo
Bunn Master
Level 3:
Answers
2239
Questions
Helped
991230
Points
5072
It's the sound of the water expanding quickly as it's nearing its boiling point amplified by the enclosed water tank inside. Normal.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Loud popping noise after click of thermostat
Clicking noises are normal...banging noises are not. Replace the thermostat.
6helpful
7answers
My cat meows very loudly in the spring. Will a cat muzzle keep her quiet?
You cat is in heat. Get her spayed if it bothers you. She will probably go berserk if you try putting a muzzle on her.
I have a new Amana PTH15E PTAC. When heat is used, sometimes is quite but sometimes sounds loud (like window AC), why?
when its quiet its the electic heat thats being used when its loud its the heating pump and the heating pump is what saves you energy and they can be a little loud when its on its normal. I work on these units at a hotel
Kenmore microwave Model No. 721.62463201 runs but does not heat and has a terrificately loud buzz. All lights displays are normal
Hello there:
There's no heat, but it buzzes loudly When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. I recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
And if you have your warranty for this you can use it to ok
Hope this helps best regards mike
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Amana microwave is loud and doesn't heat. Light
Magnetron went out causing a short-circuit of sorts. Replace magnetron.
10helpful
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
4helpful
Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
