Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
18.0 Intec OHC lawn tractor, model 247.288820. Why does fuel drain into the oil system?
  • Craftsman Master
  • 2,478 Answers
Your fuel solenoid may not working. I put a fuel shut-off in. Not in use turn off
Posted on Aug 18, 2015
6ya staff
SOURCE:
I am losing power going up hills and smoke comes out in front of mower
check for excessive oil in the sump (carby needle and seat allowing fuel to drain into the sump past the rings when standing for a period of time )
what you describe is indicative of excess oil and the oil ring cannot handle the oil control
this in turn affects the air/fuel mixture and makes it hard for the engine to run
Jan 09, 2016 | Husqvarna YTH21K46 46" 21HP Kohler Lawn...
My Craftsman lawn tractor will run for a while and then stop then sometimes after sitting for a while will run again. What should I check? I added fuel additive to gas just incase the fuel was bad.
Drain the fuel tank. Dispose of the gasoline responsibly.
Replace the fuel line between the tank and the carburetor.
Put fresh gas in the tank. See how long it runs.
While you're at it, change the oil and remove any debris from
the cooling fins on the engine. It may be overheating.
If it still doesn't run, you probably failed to replace the fuel line.
Trust me, this is part of good maintenance for these machines.
Sep 24, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
42" lawn tractor model 917.272082,
some of these have oil sensors.. you could bypass it just to check if this is the problem .. check the oil !! there is a solenoid on the carb also that shuts the gas off..jay
Jul 23, 2011 | Craftsman Garden
Specifications, for Craftsman Riding Mower, Model 247.289010. Quanity for oil.
Without an oil filter you will need approx. 48 oz. With an oil filter about 18 oz more. Hope this helps. You should have dipstick to register when it is full.
Feb 25, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn tractor is smoking
Make sure that it is at least 18 years old. Then look at the valve cover gaskets. The gaskets frequently leak and the oil drips onto the exhaust pipe. They will be near the spark plugs, have two small bolts holding them on.
Oct 30, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn mower motor
No it's sounds like the float in carb is stuck I've had 3 motors do this I put a fuel shut off in the line after I cleaned the carb out and rebuilt it. The problem is the gas breaking down an gumming up the float in carb. Drain the oil and an run some oil thur it to get the old gas out make sure you clean the carb out to.
Sep 20, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
764 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
