Washing Machines Logo
A
Anonymous Posted on Aug 16, 2015
The filter is stuck and won't budge and its also blocked
  • Anonymous Aug 16, 2015
    The front bit of the filter will unscrew but the inside part(were water is stuck behind it)won't come out for me to clean it out ???
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Aug 16, 2015
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898469
Points
3964
Brute force is the answer. Use a large pair of players or similar and it will come. Careful because if machine has not drained you will get water all over the place
doug
tip
My panel won't come off, I've taken out all the screws but it's...
This advice is for Kenmore Elite, Whirlpool Duet and Maytag Epic model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Jul 26, 2011 • Washing Machines
Customerservice
yes it does unscrew it will be tight and you will need alot of presure to unscrew try tapping it with a screwdriver handle turnig it the link below is the manual page 10 is filter change.
http://hoover.com/file/979/http://hoover.com/file/979/
1helpful
Sewing needle won't move
it could be a part is damaged or broken or a timing problem,,it
would be a good idea to have the machine checked.
1helpful
My nissan patrol 88 gq won't start after sitting
there is a filter in the injector pump, under the inlet line. could be blocked.
also try cracking the injector line and cranking the car to bleed the lines.
Tried to get hard top off my 1999 SL320. Rear points released but front ones stuck. They seem to be slightly released but roof won't budge. Rear points now out of their points and won't go bac
you need to release front points, they are partialy ceized, penatrating oil (wd40) keep working them, plenty of patience needed. good luck
1helpful
Canisters on my ge smart water filtration system gxsv10c model are stuck tight. How do i get them open
Make sure the water is turned off to system. Open the faucet to system to drain any water and keep the faucet turned on to keep pressure off filter housings.
1.Use the wrench to take housings off.
2. If they still won't budge take a small 2x4 block of wood and hammer, set the block of wood on the RIB for the housing and tap with hammer.
3. Change the o-rings in both housings, lubricate with silicone lube and lubricate the threads on housings with silicone also.
3. Rinse housings with small amount of bleach and clean thoroughly.
4. Replace filters and housings.
5. IMPORTANT: Only tighten housings by hand. NEVER tighten housings with wrench.
RJ
1helpful
2003 FLHTCI OIL Filter Stuck, bike has oil cooler, the cooler moves but the oil filter won't budge. It's a K & N filter with nut on the end, I've tried all kind of wrenches still stuck. Now I have a...
Somebody over tightened the filter. Your only choice is to force it to turn in any way possible. I've had to resort to sticking a screw driver through the filter to get enough torque to remove them. Good luck
2answers
Water filter won't come out when I push the button
Push button? It should be a turn to the left to remove if it is a whirpool located at the bottom. These are twist out not push to release. The only push to releases are made by electrolux.
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
