Power is red, status is flashing green
The ballast for the bulb is the culprit. That is the circuit board directly wired to the bulb. You can get a replacement on line at:
TV Parts Universal TV Stands DLP Chips ShopJimmy It's not difficult to change it yourself .
SOURCE: Red Status Light
Hi we have a 52 inch mitsubishi high definition tv and ours did the same thing,we had a repair man out here and he said it was the engine in the tv which we never knew tv's had engines so i contacted mitsubishi cause we didn't take a entended warranty and told them that it was not even 3 yrs old and they should stand up to there products and they did they paid for the part which was 600 dollars and we had to pay for labor....we thought it was the light to and ordered one and it wasn't it was doing the same thing yours did .....
SOURCE: Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
SOURCE: red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
SOURCE: Mitsubishi WD-73733 73 in. HDTV
Could be the ballast of your tv please check our web page so you can find it http://www.discount-merchant.com/
Said
SOURCE: status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
