Cars & Trucks Logo
Daniel Critzman Posted on Aug 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brand new weedwacker model#316-711370 first time started right up ran for awhile then just stopped,wont start at all now
Claude Kayser
Level 3:
Top Expert:
  • Cars & Trucks Master 9,098 Answers
  • Posted on Aug 05, 2015
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067195
Points
28436
#34 craftsman weed wacker manual
45.55.157.141/craftsman-weed-wacker-manual.html
100+ items - pdf download about #34 craftsman weed wacker manual ... Books Title
File Code
Craftsman Weedwacker Manual from Sears com
Free Craftsman Trimmer User Manuals ManualsOnline com
5 Related Answers
Christopher Keene
  • 201 Answers
  • Posted on May 09, 2009
SOURCE: 1988 Chevy S10 Durango Pickup, Won't start will fire
sounds like ignition module inside of distributor cap under distributor rotor button.these do go bad and can easily be replaced.strong suspicion from your details that this is the culprit.
Jonah Oneal
  • 14092 Answers
  • Posted on Jul 18, 2009
SOURCE: 93 buick Park ave ultra wont start. Turns over
make sure there is gas in tank. turn ignition switch to the on position.listen for fuel pump.if yes check for spark at plugs.if no you dont hear fuel pump.check fuse and relay.if both dont work.scan it to check for faulty crankshaft sensor fuel pump and pcm.
Jonah Oneal
  • 14092 Answers
  • Posted on Aug 17, 2009
SOURCE: Van occasionaly wont start, when left for awhile it starts
YOU HAVE DIRTY INJECTORS WHICH IS STICKING OPEN CAUSING FLOODING .WHEN YOU TURN OFF ENGINE.THE INJECTORS KEEP LEAKING. YOU NEED TO CLEAN INJECTORS.BUY A BOTTLE OF FUEL INJECTOR CLEANER.FILL UP FUEL TANK. POUR INJECTOR CLEANER IN GAS TANK. DRIVE CAR AROUND SO THE INJECTOR CLEANER WILL CLEAN OUT INJECTORS.
Anonymous
  • 5 Answers
  • Posted on Feb 09, 2010
SOURCE: 2004 Saturn Ion wont start from time to time when
LOL repeating questions. Its your ignition switch. its a common problem with ions ( I myself have a 04 ion and had it replaced twice in 3 years) repair is around 400 dollars with labor. Just google "ion not starting in cold weather" and youll get TONS of threads. No recall either its stupid
Anonymous
  • 97 Answers
  • Posted on Feb 16, 2010
SOURCE: bmw 323 gives p0340 code. dies at times when
may be time for new spark plugs
2answers
1989 honda civic wont start!
check for spark, timing, cylinder compressions, air intake if blocked can cause these symptoms,valve clearance, alternator charge rate
1helpful
Battery light and wont start 2002 Jeep Liberty Sport 3.7L V6
Sounds like you need to have your alternator checked.
I have a 2005 mitsubishi outlander. It wont start after I ran out of gas. I bought a new battery but the car still wont start
It's still out of gas until the lines are purged of air. The fuel pump has to run awhile to build up pressure. Keep cranking. If you can take the small gauge wire off the starter easily,all you have to do is turn the key to the start position and hold it there for a while. Listen for the fuel pump. When it slows down or stops then reconnect the wire and it should start.
1987gtfordmustang i replaced the alternator started the car up afew times car ran fine let it sit for a while car wont start upjust making a clicking sound replaced with new starter, battery,cable end and...
It could be the T.F.I. MODULE / IGNITION MODULE its located on your DIZZY. I've bought these brand NEW and had them not work. There are a known issue with these late model Fords.
1987gtfordmustang-replaced-alternator#solution-section-zi0u4kzo02vuv2s4hfmw5dtf-1-5.png
Ran out of gas switched tanks promblem began
Sounds like fuel filter could be stopped up.
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
Wont fire for awhile
may be the starter getting weak
My 2002 mazda tribute wont start at times
I have a 2003 tribute that was doing the same thing. It started right up but if you stopped at the store and came out it would start but not stay running. After waiting a couple hours it would start right up. We replaced the idle control valve and put in a new air filter because it was quite dirty and so far no problem. Give it a try.
1997 gmc jimmy wont start all the time
I had the same exact problem. After spending thousands on parts. It finally proved to be the CPI injector assembly. Change that and you're truck will be like a whole new vehicle. Most parts store sell a conversion assembly to MPI injection it's a much better desighn that the CPI. I was going nuts for a year chasing this problem. I hope this helps.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
