Drain pump screen is clogged. If its makeing a bad grinding sound the pump will need to be replaced. Otherwise disasembly of the machine is required to access pump area to clean out screen. Dextrous people can probaly do this from the back or underneath unit. Its difficult and I don't recomend it to beginers or people who arn't handy. Easiest/prefered method: (This is the one I use.)
Method A units that have a bottom access panel. ie: front panel not one seamless peice.
-unplug unit
-lean back against wall for easy access.
-remove two #2 square screws form access panel.
-Loosen clamp holding hose to tub. (Big black one around 2" in diameter.)
-remove and clean screen.
-reassemble machine and test pump operation.
Method B units the have seamless front panel.
-unplug unit
-remove top. 3 screws @ back, slide top away from machine to remove.
-remove 2 screws holding console onto chasis.
-remove disp
-remove 3 screws @ and behind disp area.
-Remove console. ( tab may be holding to front panel @ middle bottom use putty knife to pry up.)
-remove 4 screws holding front pannel @ top to chasis.
-remove 2 screws holding frong pannel to chasis inside machine. Acess from top. (some models only.)
-remove bottom screws either 4 or 2 usally 4.
-remove two screws holding door lock to front panel
-remove spring from around bellow.
-remove bellow from front pannel
-remove front pannel. Tilts forward and lifts up off supports. (some models only.) or pannel ifs up and off from white tabs in side of chasis.
-unhook wires to door lock from front pannel. (plastic molex tab)
-may now access pump like in method A.
Pump Replacement
-access pump area
-remove drain hose to pump by looseing clamp and pulling off.
-remove hose to tub by losseing clamp and pulling off.
-remove power connection at back left of pump.
-unscrew two philips screws holding pump too base plate. (only one is really required.)
-replace pump
-clean pump screen or add one if not present.
-reconnect hoses.
-replug in power
-reassemble machine
-test pump operation
SOURCE: Washed a small bath rug
This becomes a long drawn out process in which you have to remove the pump and the entire drain line and wash all the backing out of the machine also you have to remove the lines that go from the tub to the pump as well and even after you finish cleaning out the drain system you still will have more pieces stuck inside the tub area that you have to clean out as well. Easiest way take the machine outside or to an area you can use a hose on the unit where after you disassemble the entire pump area that you can wash the tub out of all the small pieces of the rug backing I had the unfortunate repair of doing this to someones rubber backed rug cept it took all the rubber off the back of the rug. It took about 3 hours with hooking and rehooking the drain lines and unclogging them over and over due to this unit I was working on was in a basement and no access to a hose If you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks again Rick
p.s do this repair yourself a repair technician would charge about 200 to repair the unit due to the amount of time
