Already tried clearing drain tube, melted ice on coils and drains, checked for any crimps in lines.
SOURCE: ice at the bottom of the freezer
bottom of rezzer compartment is supposed to be frozen( depending on timeof cycle) i wouldnt point to a defrost problem unitil the ice build up is hindering refigeration, its quite possible that thte defrost drain has just frozen itself over, and needs to be cleared to allow defrost water to go into the drip pan under unit
SOURCE: Water leakage under freezer door-ice on bottom of inside of freezer
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
SOURCE: Where is the drain located?
Hi, The drain is located behind the rear inside freezer panel. Remove the panel and find the drain hole under the evaporator coils.
I hope this helps you.
Vic
SOURCE: Water pooling under freezer side of cabinet. Ice
drain in bottom fo reezer is frozen w/ice (location is very far left in back lookbehind vent. use hot water and baster. force hot water through drain. /remove ice /it will work good. mm pls leave feed back..mm
Testimonial: "thanks very much, it appears to have done the trick. I wonder what made the drain clog up in the first place"
