Shirley,
There is a plush carpet attachment that you can purchase for your Oreck. If you have an Oreck dealer near you, they should have one. If you are not sure where a dealer is near where you live, you can go to Oreck's website and use their dealer locator to find one.
Oreck Store Locator
SOURCE: I have a Lux Floor Pro Heavy Duty carpet cleaner.
NEVER USE THE HARD BRUSHES ON CARPET ! You can burn up your motor, break the drive belt,or strip the drive gears The black bristle brushes are for all carpet types.
The hard bristle brushes are made for hardwood and other smooth surfaces.
SOURCE: On a plush carpet, the machine is not picking up
replace the rubber belt that should fix it if not let me know
Testimonial: "the belte were the answer. Remember to replace both, they are interactive. Thanx for your help!"
SOURCE: Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
hooked rugs produce the highest amount of friction opposing the brush rotation, which can over heat the drive motor. try using a height setting that raises the brush so that it barely touches the pile. If this issue has been going on for some time, you may need to replace the drive motor.
