Question about Kenmore Washing Machines
Where is the model # on kenmore top loading-high efficiency low-water washer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 413 Answers
Should be just under the lid back by the back of washer.
Posted on Jul 29, 2015
Anonymous
SOURCE:
Tip
Top-Load vs Front-Load Washers - Things to Consider
The traditional top-loader is more comfortable to load and cheaper to buy. High efficiency washers in top-load or front-load models are much more expensive but are water and energy savers, with front-load models having the best energy ratings. Front-load washers have a better spin which leaves less water in the load causing less drying time. High-efficiency models require low-sudsing HE detergent due to low water levels and they require a little more care. They also have more cycles and convenience features than traditional top-loaders. Warranty periods generally are a year regardless of washer style.
on Aug 17, 2010 | Refrigerators
We have a Kenmore top-loading high efficiency low-water washer that we purchased last year. It had been working perfectly until the other day. When I try to start a load, water is going into the the...
Have any modifications been made to drain? If drain hose is too low or too far down in pipe or installed airtight, it can act as a siphon draining as fast as it fills.
Aug 31, 2017 | Kenmore Washing Machines
Kenmore top load HE not drained after heavy load. Now when you attempt to start the sensor locks door and than unlocks and will not run
First you need to list the model number and possibly the serial number if you can find it in order for me to figure out what type of washer it is then i can help you. Thank You. You may need to re-ask the question with the model number and serial number or email me at etsi00257@hotmail.com because i am a certified appliance repairman.
Mar 10, 2013 | Kenmore 3.6 cu. ft. High-Efficiency...
Does kenmore recommend liquid or powdered detergent for front load machine
liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis 2709 water level problem
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 09, 2010 | Kenmore 4292x Front Load Washer
Washing Machines Logo
49 people viewed this question
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
James Hensley
James Hensley
