Try to keep plugged in charging 1 or 2 hours and check the status of charging light it must change from Red to Yellow or Green.
Had a scary problem with my Dragon Touch A1X Plus 10.1 and I fixed it. It would not turn on at all, not even to see the battery level. NOTHING. There is a tiny hole on the side of the tablet where all the other functions are. It's called RESET (printed on bottom of tablet under the hole) I put the end of a paper clip in the tiny hole and held just a few short seconds till it came to life with the battery level showing. It was fully charged so I just started it normally with the start button and it worked fine. Good luck, I don't know what model you have but it should be a similar fix.
If is itunes compatible just hook up to computer running: tunes/ if not can do reset by pressing volume up key, home key, and power key holding till reset screen appears.
SOURCE: how do I set the system time on a seven inch
Hi Leah,
Here is the short answer:
Here is a good tutorial: How to set the time date and password on an Android tablet
Hope this helps.
looks like it requires a disassemble and replacement of a few parts. Good luck finding parts. If u r cleaver u may be able to jerry rig something
SOURCE: How do i reset my android dragon touch tablet
Just thought I'd share ...... My problem was, I brought a brand new Chrome Tablet from Amazon that was stuck on a password page I never made it through the steps to set up my tablet. I didn't have a password & the vendor couldn't help. To hard reset my Chrome Inc Tablet, I held the power button & volume UP button at the same time until the recovery screen came on. The recovery screen shows a robot laying down with an ! mark. Then, while still on the robot screen, I pressed & held the volume UP button again until a list of recovery options came up. You use the volume up & down buttons to high light the option you want & then press the power button to select. I selected the wipe/out - erase data option and it worked. It took the tablet to the factory settings the way a brand new table should be.
You need to install a PDF reader. PDF is copyrighted format. If it is an android device start the Google Play app to install adobe reader.
