Vacuums Logo
Bob Simons Posted on Jul 25, 2015
Shop vac weak suction. new filter has worked.
Matt Roden
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Jul 25, 2015
Matt Roden
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
6060
Points
29
If new filter doesn't do it, then check hose for debris
I’m happy to assist further over the phone at https://www.6ya.com/expert/matt_0c9009be7d775298
2answers
Hoover S3639 Suction Failure/Turns itself off and restarts later
If you did all this already the motor is not having power, must be replaced.
tip
How to diagnose a clog in your Central Vac and how to remove it
Symptoms of a clog
Low Suction/No Suction
No suction at Inlet
Tools required
Wet/Dry Vac or vacuum with decent suction and a hose
Phillips Head Screw Driver
Metal Coat hanger (straightened out)
Flashlight
First things, first, make sure your canister is empty at the unit. I know, most people would have already checked this but I have been to a lot of client's homes and this was the issue. They were full or almost full. So just check it before you go to do anymore diagnosing. I suggest emptying it anyways, this way you can see what you clogged in your unit
Now if your machine has a utility valve on the unit turn on the manual over ride switch on and lift the utility valve and if you have suction your machine is fine, you have a clog. If you have no suction or poor suction
-Canister not attached properly
-Filter clogged
-There is a disconnect of pipe within your walls (I've seen it and it renders your system useless and is going to be expensive to repair the system)
-Your motor is going in your system (Your vacuum should sound like grinding metal and chances are it's throwing sparks and smells of burning electrical, turn the unit off immediately and unplug power cord) Your unit will need a new motor or you will need to replaced the whole unit. Sometimes can be cheaper to replace the unit.
So now back on track here, we are going to say the vacuum has great suction and is running smoothly.
Check your hose for clogs, easiest ways are to plug the hose into the utility valve and turn on the machine manually at the switch.
If you do not have a utility valve on your unit (this is where the other vacuum comes into play) plug your central vacuum hose on the end of the shop vac hose. Most hoses are standard and slip right on over the end of a shop vac's hose end (1 1/4 inch end). Turn on your shop vac and feel the suction at the end. It may not be as powerful as your CV but it should be comparable.
If the hose checks out to be free and clear we have a clogged system.
Now lets move to the inlets throwout your home, first we are going to plug our hose into the inlet that is nearest to the unit. If there is little or no suction we know there is an issue either in the distance between the nearest inlet or there is an open/broken valve.
Open/Broken valve (CV will not provide optimum suction with a open/broken valve)
-Plug the hose in and activate unit
-Check all inlets for proper seal, you will hear an annoying whistle or you will hear a gust of air from an improper inlet door closure. (Do this as quick as possible, if it is a clog you are putting strain on your motor, but if you vacuum on a regular basis chances are you know if there are whistling noises or missing pieces of an inlet. If you are missing an inlet door, replace the inlet. If all is checked out to be good, lets go back to unclogging again.
If there is suction at this inlet you know there is no clog between this inlet in the unit, try all inlets from nearest to farthest away. If you try your next inlet and have weak to no suction you found your point of a clog. This is where you will start to unclog your unit.
Take the hose end of your shop vac and insert it into your inlet. Turn the shop vac on and remove the hose quickly to create a seal and lose a seal. You should start to hear items moving through the line.
Now take your CV hose and insert it into this inlet, activate your CV and check suction if there is more suction, your slowly making progress.
Take a flashlight and look into the inlet to see if you can now see the obstruction. If you can, get your coat hanger out and go fishing. It may be easier to remove the inlet from the wall. Your basic valve is safe to remove. If you have a supervalve, do not remove, there is high current installed in the upper portion of the inlet for your power nozzle.
Repeat the Shop Vac suction and stop and the CV suction and stop until you clear your items.
This is going to take a few minutes of tugging between two vacuums. Eventually it will free if it went in, it has to come out. At the end of the day your basically playing tug of war between your Shop Vac and CV. But if all goes to plan, the clog will end up in your shop vac or in your CV unit.
Good Luck!
on May 13, 2014 • Vacuums
Weak suction shop vac
Is the tank filled completely with dirt? When was the filter last replaced or cleaned?
May 15, 2012 • Vacuums
2helpful
2answers
My vacuum tools have very weak suction.
There is a foam ring filter in the bottom of the canister that collects the dirt. It screws off of the bottom on the canister. Take outside and shake it out. It fixed our suction problem.
1helpful
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
May 01, 2009 • Vacuums
2helpful
MY SHOP VAC STOPPED WORKING AFTER USING IT FOR A WHILE
If by stopped working you mean that it no longer has any suction, then check the hose for a clog and also clean all the filters.
If you mean that it literally stopped running, then the most common cause is a faulty switch. If the machine is still under warranty, contact Shop Vac for a replacement motor, Switches for shop vacs are not available, only replacement motors. If the machine is not under warranty you can either replace the motor or the whole machine.
Little suction in craftsman canister style carpet/floor cleaner
you might have a leak on the suction side...perhaps the housing is not properly secured, or there is a **** in the black plastic hose.
Automatic pump for 10 gal shop vac
first you have to remove the filter in the vac then at the bottom of the vac tyhere should be a cap you remove and screw a water hose on and run it out side then when the vac fills the water will run out put the main hose on the suction side
Top Shop Vac Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
