If it is over heating that is causing it to ever heat then you need a new thermostat, If it is just over flowing the place a check valve into the input line and that will stop the over flow
Col. Dana Gillespie
If the car overheats also, replace thermostat.Could be heater core needs to be replaced, Any water on passenger side floor?, or smell of coolant?or are windows misty on inside of car?when you slide control from cool to heat it is supposed to close a door that lets in cold air, make sure thats working, usually you can hear it shut. lastly, check water pump. You do have enough coolant in system right?
You may need a new cartridge, that error says the ink cartridge is wrong or not installed properly. If it's a refilled cartridge it won't work, if it's a new canon cartridge, they warranty for 30 days from date of purchase.
you have to pull the wheel, lock plate which will require a loner tool then it is all a matter of some screws and wires be careful when removing and re-feeding i would recommend a shop do this if you've never done this before
You may need a GOOD new thermostat. I had the same problem twice on my first generation Dakota. The problem for me turned out to be the DODGE thermostat I used to replace the old Dodge part. I went and got a Stant brand from local auto parts store using the standard temperature spec and quit shivering the next time I drove it. I don't know if your engine is a Dodge or Chrysler engine, but it sounds like the same thing.
I am having the panasonic printer,the model no.is kx-p1694 but the problem is the head of this printer is damage.I need new head of this printer .If u find the head of this printer then email me . My email id is [email protected]
