Confirm that the motor(engine) turns freely. Confirm that the PTO blades are not engaged. Confirm that the shift is in neutral.
Confirm that the starter solenoid has not corroded internally providing a low current to the starter. Jump the solenoid. Check for corroded battery connections.
See image using multi-meter check for voltage drop between battery and starter while cranking. Connect multi-meter directly on to the battery post and onto the stud of the starter. Less then a volt!! If not try jumping the starter and see if it cranks as expected.
Confirm that the battery voltage is above 9 volts DC when cranking. If below 9 the battery is weak.
Remove starter and turn by hand the shaft checking for lack of lubricant or excessive corrosion internal on the stater.and winding.
The starter would likely have dust and low lubricant before bearings wear. If you are not qualified to inspect starter check around for a local starter/generator repair business and see if they would service the starter. I expected that it can be cleaned, lubricated and returned to service for less than a replacement. Check online repair service or online rebuilt?
Hope this helps?
