Refrigerators Logo
Hi. I just replaced the HV board with part #W10310240. The lights are now flashing an error code PE0 000 Can anyone advise me now?
3 Related Answers
Anonymous
  • 1382 Answers
  • Posted on Apr 14, 2010
SOURCE: Error codes flashing
Hi, This is mainly due to control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually..
Anonymous
  • 4889 Answers
  • Posted on Oct 23, 2010
SOURCE: I have a TH42PX80U which with one tuner board will
Which begs the question how many times does it blink in between each pause? It is a diagnostic error code that will help us zero in on the problem.
Anonymous
  • 3344 Answers
  • Posted on Nov 27, 2012
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: E332n lights flashing error
    We would need the secondary codes to get the root cause of the problem. Press the Continue button twice to get the secondary code.
    Ir105 canon model error code E000068-0000
    Hi Mohammad.
    There is an error in the high-voltage output to the separation charging assembly.
    An error (leakage) to the high-voltage output to the separation charging assembly is detected.
    Check if the transfer charging assembly and separation charging assembly are mounted properly. - Check if the connector (J722, J723, J730, J734) of the HV-DC PCB and the connector (J741, J742) of the HV-AC PCB are mounted properly. - Replace the HV-AC PCB. - Replace the separation charging assembly. - Replace the pre-transfer charging assembly. Canon iR105 Error Codes List page 3 from 9
    2answers
    CS Code
    Inspect foil side of HV board for burned tracks toward lower side of board. If burned, check HV capacitors (High Voltage Capacitor Test Procedure) and HV transformers (High Voltage Transformer Test) for a short. Otherwise test other components as outlined above.
    Solution: Replace defective components as necessary. If applicable, repair foil trace on HV board.
    Hope that helps.........
    Anyone now the fault light codes for this model---thank you
    Flashing Lights & Error/Fault code - Repair
    www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
    Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
    Identifying Hotpoint or Indesit Error Codes - YouTube
    ? 6:46
    https://www.youtube.com/watch?v=aud14I0Zu9M
    Aug 29, 2014 - Uploaded by eSpares
    If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
    Flashing Lights on Washing Machine How to Repair ...
    The control panel of my AFI2538AES is blinking and the ice flap opens and closes continually
    The cause is a shorted control board and this unit will require a new one to function correctly part number W10310240 this is the number for the information you provided. Normally the run number is an issue but all 12 of the model numbers use this board. Good Luck
    PS. Part name is Board-HV Control Iceland
    I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
    E44 = ?
    Good Morning bennysia28 - Typically, error code E44 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
    Control Panel not working model MFI2269VEW1
    I have found when the control panel will not respond the the HV board is defective Part# W10310240
    http://www.on-timeapplianceplano.com/refrigeratorrepair.html
    I have a magic chef S68-3cxw electric stove/oven. It is flashing f2 can anyone advise what F 2 stands for
    Hi, the F2 code on the Magic Chef Oven implies that the Oven temperature is too hot.
    The solution is to replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness...
    5helpful
    4helpful
    Error code 43 on F& P washing machine
    Carefully remove control console, then control board. Take note of which connector came from which terminal! Balance sensor is located under control board. Remove with care. Check that little button (size of pen top or pencil lead) is moving in & out freely. It is spring loaded. If it sticks, replace it. Hope this helps.
    Top Amana Refrigerators Experts
    ZJ Limited
    ZJ Limited
    Jay Finke
    Jay Finke
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
