There are three exposed screws on the bottom of the machine that can be removed with a Phillips screwdriver. You also need to remove two of the four rubber feet with a Phillips screwdriver. The other two rubber feet also need to be removed, but they have some kind of specialty screw that needs a split-head screwdriver. I just removed them by twisting the entire foot with a pair of pliers. Then the panel pops off fairly easily, and there's the belt. As an aside, the drive belt on mine kept coming off, and just putting it back on didn't help because it would just fall off again. It turned out that the whole bottom of the machine was bent, so the motor gear wasn't lining up with the drive gear. Not sure if this is fixable.
5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine.
If you need help open a post in that repair forum and I will try help you through your issue.
The forum is free and my time is free I just don't want to waste my time in this forum. If you need additional help to troubleshoot the ND error code re-post in that forum.........D*ick
A shot with the front cover off looking into the drain pump/pressure switch. Look like fun right.
In this post Clutch Fix the first couple steps will help you get the front cover off. See ya on the other forum if you need additional help.
this link is broken :http://www.cuisinart.com/share/man/483_m...
