SOURCE: USER MANUAL FOR RUSSELL HOBBS CJS28 MICROWAVE WITH CONVECTION
Their customer service # is 0845-658-9700, their business # is 0161-947-3000, and you can e-mail them [email protected]. I could not find a manual on their website so I guess you will have to the above #'s wurstdude
SOURCE: Bulb blown on Russell Hobbs CJ/AL28 microwave
Just open the top cover and find the location of the bulb , it may be in the right side near the control panel. Remove the bulb and get a similar bulb with the same rating from any electrical shop and fix it
SOURCE: Microwave is just over 1 year old and has stopped heating things
Most micro's have a % heat setting. Make sure that you are at 100%
SOURCE: My Russell Hobbs microwave will not generate heat
If everything else is normal, the trouble may be a failed magnetron tube (the microwave source), problems on the control circuit board, or parts in the tube power circuit that are bad. It's also possible a door switch can be at fault, but this usually keeps something else (fan, turntable or light, most often) from running as well.
Microwave servicing is best left to professionals. There are potentially deadly voltages present, and a chance of microwave leakage if repairs aren't done correctly. Take the oven to a shop for an estimate, or just consider replacing it if it isn't a built-in, an over the range unit or a high-end countertop model.
SOURCE: how to set the clock on my Russell Hobbs microwave RHM2016
First of all, thank you very much for choosing FIXYA today for your technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.russellhobbs.co.uk/pdf/product_387_rhm2016_ib.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 8 of the manual for detailed instructions on HOW TO SET THE CLOCK on your microwave. Basically it says to press the CLOCK button, then press the CANCEL button, then enter the current time using the number buttons, then press the CLOCK button again to set it.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
