Sounds like the evaporator coil is icing up. Once the coil ices up no air can flow through and you essentially have a very large ice chest. The thermostats on these coolers are actually sensing coil temperature not air temperature. I would want to check that it is set properly and that it turns the compressor off and on. If you have an old mechanical thermostat with a knob with settings from 0-9 it should be set on 4-5. Anything higher and it WILL ice up occasionally.
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
i have a maytag two door fridge it's not working the fan is working but it's not getting cold fridge or freezer can you help me sometimes it tries to cut in makes some kind of sound for a couple of sec and stops again
SOURCE: Refrigerator/freezer just quit. Lights are still on
What has quit? The cooling of the refrigerator or the ice maker/ dispenser?
