SOURCE: Broken glass face on Ecclissi
Being a branded company it is not possible to fix the glass by yourself, you have to buy a new glass or i strongly recommend you to get it repaired.
Here is the customer service no. you can contact them and ask about the nearest authorised service center in your area.
[email protected]
[email protected]
800.358.8039 toll free
212.967.5666 tel
212.695.0706 fax
Goodluck...
SOURCE: dont know battery type for ecclissi watches?
Measure your original watch battery (diameter and height).
Compare with the cross reference list and find exactly what you want.
List is here: www.battery-info.co.uk/watch-battery-cross-reference.html - 19k - Cached - Similar pages
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
SOURCE: I have a Timex Indiglo watch that I
This watch will have what is called and "AC" or All clear to reset it. There should be a white sticker with very small print on the back lid that will walk you through doing this procedure. It typically involves pressing down a tiny lever onto a small metal pad that will reset the watch.
