An answer found on a BOSCH support site said:
"the E:01 indicates a door lock error, make sure the door is closing tightly, you also may have a loose connection on either the door latch assembly or the control board, if these check out replace the latch assembly."
Since you've already replaced the mechanism then it seems possible a loose -connection- may be your problem. If you've already checked all this, please post back.
SOURCE: Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
SOURCE: my bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
SOURCE: TURN OFF ALARM
Assuming you have allready checked the operators manual, check again on page 19 for "Accoustic Signal". To deactivate the signal select a program press two of the option buttons and hold until a short signal is emitted. There you have it.
SOURCE: Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
SOURCE: The water won't drain from my Bosch Nexxt 500
I solved the problem by using a sump pump to drain most of the water, then I removed the cover plate on the lower front right of the machine to get access to the drain plug. Upon removing that, some water flowed out but not too much, I found a sock jammed in there which wasn't allowing the drain or spin cycle to work properly.
Interestingly, the machine's manual says that the cover plate is only to be removed by a Bosch authorized service repair representative. Saved about $150 by simply doing this myself.
Removed back panel and pushed all connections. Removed top cover and did the same. Still locks, clicks two or three times for 2-3cycles and then flashes e01
