Pride Master
- Posted on Jul 10, 2015
Re: The motor is spinning but the drive is not engaging...
Okay now have you removed the motor from the gearbox, if so did you refit the coupler that located between the motor and gearbox, another cause is a sized brake... I can help in all cases , UK based ?
Regards
Rob
www.gewizrepairs.co.uk
Thanks Rob I did remove the motor from the gearbox and made sure the coupler was in place and engaged I also removed the brake and wd40'd it I couldn't find a problem and it worked fine when I reassembled it all ..I'm still not sure where the proble was but it is working now. I also put a key in the left wheel it didn't have one and the axle was spinning in the hub.
