Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series Logo
B
Bruce U Posted on Jul 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix samsung tv no picture just sound
I replaced the powersupply/led board Part no. BN4400666A and still the same. I checked to see that the backlight was working and it was not. I did a flashlight test to see if I can see the menu on the screen and it does turn on and off.
Mikey
Level 3:
Top Expert:
  • Samsung Master 6,903 Answers
  • Posted on Jul 06, 2015
 Mikey
Samsung Master
Level 3:
Top Expert:
Answers
6903
Questions
5
Helped
1620650
Points
26101
Since you have replaced the LED board and you can still see a faint menu screen, this would indicate the LEDs have blown! Replace the backlight LEDs.
Testimonial: "Thanks Mikey, Are those the black rectangle boxes on the bottom of the panel?"
  •  Mikey
    Mikey Jul 07, 2015
    Not to sure about your model but usually they are to either side of the screen, check this YouTube link for more help:https://m.youtube.com/watch?v=8HG7efTMj7...
Samsung led tv gets power but see no picture. sometimes have heard sound when toggling through inputs. I replaced the T-con Board and the TV worked fine for a while. Now I'm not sure what to do.
LG LED TV has no picture (black screen) but still has sound - can ...
www.tomsguide.com/answers/id-2660992/led-picture-black-screen-sound-fixed.html
Feb 9, 2017 - My 32' LG LED TV has suddenly lost picture! The sound is alright but the screen is pitch black. ... Then completely black but with audio. ... I'm really hoping if I do the right research Ican fix this tv for my husband. .... Take the screen off hit power and watch LEDs if any don't flash its LEDs if they all flash its ..
I have a samsung Un55J6200afxza. sometimes when i power on the tv there is no backlight.
It could be a defective main board, or intermittent LED diode on the back lights strips.
I will try a new main board first.
2answers
Samsung UN60FH6003F Power Supply / LED Board BN44-00669A went bad in my samsung tv and when I replaced it , it blew out as soon as I tried to power up, what could possibly be my problem
Danny what ac voltage is in your country?
is it for example 240 volts 50 hz and what voltage was the power supply designed to work on like was it 120v 60 hz
it may have an option to switch between 240 volts and 120 volts ?
If this was the situation did smoke come out of power supply as the electrolytic capactors in the power supply have a voltage limit and blow up with smoke. I can't tell what other damage could have been caused to the television or power supply if this was the cause ?
2answers
Bad power/LED board in Samsung UN39FH5000FXZA, Version PF03?
Yes. the ballasts are combined so you'll have to get that board. Shopjimmy has a repair service or you can get a new board from them. TV Parts Universal TV Stands DLP Chips ShopJimmy
3answers
Bn44-00666a led voltages
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
1helpful
3answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
How do I fix samsung tv no picture just sound I replaced the powersupply/led board Part no. BN4400666A and still the same.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
