P0302, see I now it, but is it only 1? DTC error?
2 engines , or where? and up to 5 world wide, NO VIN
Engines, Mitsu. no clue told.
V6 2.7L? (so says dodge.com USA> go this?
2.4 L EDZ I4 4G64 I4 DOHC and SOHC
2.4 L EDV/EDT turbo I4 (Mexico)
2.7 L EER V6 )
i GUESS THIS IF Usa CAR. has 6 COPS
Coup?:
2.4 L 4G64 I4
3.0 L 6G72 V6
my best guess USA is
VIN K engine, no vin told so engine is UNKNOWN,
it means, this, only.
Low combustion on #2 cylinder, (spark,fuel injection or compression bad)#2
#1 is on crank pulley end. #4 is at transmission I4, F1234R
rear means tranny end. oK?
v6
all V engines 99% #1 is the bank V that is most forward cyl. of all.
to the crank pulley's
2nd is always 2nd in firing order, always,and PCM dictates it.
2.7l v6 24v ffv . dohc mpi engine.
firing order, 2.7L 1-2-3-4-5-6
even odd ;odd banks.
causes (v6 cops)
1: spark plug bad #2
2: spark coil bad, COP 2 dead? or weak or boot bad.
3: oil flooded inside the spark plug well, shorting all above out.
4: injector bad #2 (omg PCM, nah) swap 2 top find it;
5: compression fails #2
only 1 code told so answer is 100% based on 1 code only 302
6: rare bad cam lobe.
7: rare cracks in head , antifreeze leaks to #2 combustion chamber.
8: oil leaks to #2 via all classic ways.
3.0L v6
2.7L
2.7L V6 order
1-2-3-4-5-6
