It has nothing to do with freezer operation, its there to let you know there is house power to the freezer. It was designed to let you know if the plug accidentally fell out or if the breaker tripped for some reason and there was no power to the freezer.It has nothing to do with freezer operation, its there to let you know there is house power to the freezer. It was designed to let you know if the plug accidentally fell out or if the breaker tripped for some reason and there was no power to the freezer.
so its not mandatory to get the light fixed then?... should i just let it go then?...so its not mandatory to get the light fixed then?... should i just let it go then?...
No--not mandatory. Freezer will still work if it burns out completely. Its a feature for your peace of mind. If light is on--you know there is power to the freezer and it should be working. The other side of coin is the light could be on and the freezer could still have a problem and not work so its just an option that helps monitor the operation. It up to you if you want or need the light. If you go into the freezer and check it on a regular basis then the light doesn't matter.No--not mandatory. Freezer will still work if it burns out completely. Its a feature for your peace of mind. If light is on--you know there is power to the freezer and it should be working. The other side of coin is the light could be on and the freezer could still have a problem and not work so its just an option that helps monitor the operation. It up to you if you want or need the light. If you go into the freezer and check it on a regular basis then the light doesn't matter.
You can't post conmments that contain an email address.
Sounds like a [i]possible[/i] short in your wiring loom / harness.
Get an auto electrician to go through your wiring system.
From a first-hand incident, an unattended short [i]could[/i] result in burning wires / fire.
must be the power supply or a fuse ,does the fan come on and a orange light beside the power light flick on and off?if so count the blinks before it shuts off could be the lamp program also,just refer to the manual that you can download freee from JVC M anuals and count the amount of orange flickers.
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/
There
are more than two thousand and four hundred posts. All are related to
television and other domestic electronic equipment service help.
30 seconds is quite a long time for a camera on start up but I don't have the start up time specifications for this camera. Now for the orange light flickering after a shot the lights are telling your the pictures is being loaded to your memory card. It still seams like a long time to be loading a picture but I don't know where you has set the quality level of your photo's another thing is formatting the memory card. The memory card needs to be formatted to the camera it is being used in, if this card was not formatted I'm surprised it's working at all. My suggestion would be to download the pictures from the camera to your computer Hard Drive eject or safe disconnect the camera "drive" different computer call it different names. You must stop the card before removing the USB cable. Once the pictures are on the computer hard drive then format the memory card this will clean all the pictures off the memory card and make it ready for new pictures.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
this is common within your product series. i actually havent seen one that doesnt do that. it either means the battery is dead or the motherboard is bad. and im starting to lean tword motherboard only because this is such a comon problem. and even after people buy new batteries, it still does it. so i believe its your motherboard.
sounds like your ac plug to the laptop might be loose you can try ans see if you can resolder it back. the other problem is your ac cord might be broken wiggle it around see if the light flickers.
ty jerry.... is that a necessary issue or just can i let it go
