Question about Arcade Alley Alley Electronic Double Hoop
Arcade alley hoop to hoop assembly instructions
Assembly instructions
Adjustable basketball hoop
push on the back board up to get it to lock. Use the catch plate to bring it down.
Jun 14, 2016 | Spalding 72351 Portable Adjustable...
Need instruction manual
http://www.instructionsmanuals.com/
Feb 14, 2016 | Spalding Basketball Spalding NBA 66349...
How can I buy the parts for this product?
Go to Home depo or hard where store that sales plumbing pipes. Take one of the pipes with you and match the size to the L joints they have. Spray paint black to match and down. A whole lot cheaper then buying the original L joints.
Jul 24, 2014 | Harvard Double Shootout Arcade-Style...
How do I fix a wobbly in ground basketball hoop
I would clear any loose debris, repack around pole with a dry concrete mix then add water to it make sure pole is level, brace if necessary and give 24 hours to set up.
Apr 18, 2014 | Basketball
How to fix my basketball hoop
Your either going to have buy a new one which I'm sure you want to be a plan Z. With that said, your going to have to weld it at a position that is not adjustable or is possible weld and screw 2 sides where it can move at the broken angle
May 26, 2013 | Basketball
What the Problem
You need to give us a better picture and description of your problem. It looks like you are working with a basketball goal that is laying down on the ground. Do you really mean only the "Net," or are you using the word net to mean the whole backboard mechanism? Are you talking about hooking the strings of the net to the orange "hoop?"
Is this the first time you have tried to raise it, or has something changed after you have used it successfully for awhile? Is this new and you put it together yourself? If so, you probably made a mistake. Review the instructions, or ask a mechanical friend to look at it.
Often the answer is easy - its asking the right question that is the hard part! Hopefully you can understand that you have not yet asked us the right question.
How to setup a rawling softee hoop set
Unfortunately, I couldn't find a manual or instruction guide online. Here is the contact page of the Rawlings website. They should be able to help you assemble it.
Feb 24, 2013 | Rawlings Michigan Wolverines Slam Dunk...
How to install above the rim basketball hoop system
I believe this is the product you are referring to. The link is to the item on Sears' website. You should be able to find a manual there.
Jan 28, 2013 | Basketball
Arcade Alley Alley Electronic Double Hoop Logo
838 people viewed this question
Top Arcade Basketball Experts
Tom Chichester
Meli Dragon
Meli Dragon
Helen Walton
Helen Walton
Are you an Arcade Basketball Expert? Answer questions, earn points and help others
