I have an Aqua Glass Hot Tub that came with the house I bought but when I push the On'Off Button nothing happens. I found the pump in my closet on the other side of the wall and I can see it's plugged in. I have no idea what Model it is other than it saying Aqua Glass although I am still trying to figure that out. At the moment all I have found is the Pump and some small black box above it that looks like an Amp. I googled around and have no clue still. Any ideas how I can find what I need so that I can look into fixing it?
First check the breaker box for the house and see if it has power.
Testimonial: "I appreciate the advice. I checked but my circuit breaker shows there is power for it turned ON."
Unfortunately, that didn't help. I just checked that and I see the power for it is set to ON.
Make sure it is not on a GFI breaker (those that have the two buttons in the middle of the outlets) check all those in the house to make sure none are tripped. When that is complete, I see from the pictures that the switch is a push button surface mount by the spout. Those switches are actually small air pumps that attach to the switch box with a hose. Check the hose for leaks etc.
Thanks! I think that did the trick! But I won't know for sure til later on today when we put water in it to fully test it to be 100% sure about it. I found a GFI Breaker that was in the wall by itself with no plugs behind my bathroom door which I found was OFF and I wasn't sure what it was for at the time so I just RESET it and tried the Hot Tub again and now it turns ON and OFF as it should. I checked the pump plug in my closet and found it's on a normal plug so I am guessing they routed it through that. Anyhow though, Thanks a bunch, I believe that will work!
You are welcome
UPDATE - Just wanted to come back and let you know that fixed the problem entirely. We did test it and it's working perfectly now. Thanks again! :D
