Check this Asus community forum
ASUSTeK Computer Inc Forum laptop bios password reset
SOURCE: Hard Drive Password Lock out
If you are able to locate either the jumper (JBAT1) terminal from pins 1-2 to pins 2-3 for a few seconds and then back to pins 1-2; or the cmos battery(remove for about 10 minutes) which will be on the motherboard although where is anyones guess, unless somebody does know, but i'm sorry i don't. Athough this may not open up the hardrive as sometimes there is a hidden file on some manufacturers hardrives that sometimes prevent formating.
SOURCE: remove password from award bios on asus laptop
can u mail me a test mail by ur id so tht when ill get the ressoluiton ill mail it to u and thre no such thing as no soltuion if ther e isno solution i have the resoltuion
Click on the link below and follow the instruction
http://www.fixya.com/support/r1257563-break_bios_password
SOURCE: forgot asus laptop password Windows vista
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
SOURCE: My Asus Laptop model is
Once BIOS password is set you can not change it. You can try to remove the BIOS battery for 24 hrs and see IF this works or call the manifactor for advice. Normaly they will tell you where to take it in for repairs. Again, once the BIOS password is set You can not change it.
