LG 42LC2D 42 in. LCD HDTV Logo
Bill Innes Posted on Jun 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red light flashes TV comes on the goes and stays off for a long period then returns for seconds before going off again.Could this be an Ir remote sensor issue?
Was originally only going off for a few seconds and the picture would return.
George Allison
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 31 Answers
  • Posted on Jun 23, 2015
George Allison
Contributor
Level 1:
Welcome Back:
Answers
31
Questions
5
Helped
6851
Points
57
With the Information Given, replace power supply Board,
jukeymart
Level 2:
Champion:
  • Expert 244 Answers
  • Posted on Jun 22, 2015
 jukeymart
Expert
Level 2:
Champion:
Answers
244
Questions
Helped
51740
Points
306
Sounds like a power board fault.
1helpful
2answers
Can a symphonic TV model WF203 be put in video mode without a remote
Only if you have a source button on the tv itself. On many of the newer sets you have to have the remote to access your other inputs. Without the remote, nada. And forget universal remotes - they only provide for the most basic functions and video source is not one of them. And you get hosed on original remotes.
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
1helpful
Hi, We have a 42" hslc10668phz
generally when you get a constant green light all is ok. these different lights indicate different problems within the tv. so the pattern of lights you mention suggests there is a fault of some kind (is there a troubleshooting section in your manual)? either way it needs to be looked at.
18helpful
2answers
Red ir light floashing and tv wont come on Onn lcd tv
red light flashing on bottom of tv and no picture
2helpful
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
3helpful
3answers
Piece of s@#t!
Sounds like you  accidentally "set" the parental lock while you were sleeping.
Try this trick: (may or may not work)
aim the remote at the TV "IR sensor", hold down "display button" on the remote for 10 seconds to erase or clear the password.
"IF" this works go into the menu and "TURN OFF" parental control.
3helpful
4answers
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
