A number of years ago I bought an Aquatak Go pressure washer. After a few uses my son managed to damage the lance so the unit was stored in a garage cupboard for a good 3/4 years. Just recently I bought a new lance and used the unit for a good 2-3 hours. I made sure it was drained before storing it away again. I got the unit out to finish the job, connected the water supply, plugged in and turned it on. The motor came on for a couple of seconds and then stopped. I was using an extension lead so I plugged directly into the power source but still nothing. I replaced the fuse in the plug but still nothing? Anybody got any clues?
At a rough guess I would think that there is a blockage in the wand jet at the end or the hose has a blockage inside it.
Testimonial: "Thanks for your response Bill. I checked the hose and actually had the hose connected and the lance still sprays even without the power on so I don't think there can be a blockage in there."
Does the motor have rust in it??the motor can be replaced
I can't see any rust in there johnny. It seems that odd that it worked fine for a few hours one day and then a couple of days later there is nothing but I can only think it must be the motor, now to decide whether to get it fixed or just buy a new one!
if you have all the parts,hose wand fittings etc,the just buy a motor,or used washer with a blown pump etc.check ebay
it could also be the pressure switch,i myself would check voltage to the motor and from the main switch etc,there are alot of pressure switches on ebay so that makes me think that this switch is a problem on those bosch washershttp://www.ebay.com/sch/i.html?_from=R40...
