Fault code 04, 05, 21, 42, 43 and 44 all relate to a motor error. So check your motors carbon brushes for excessive wear, check the electrical plug for any damage or corrosion same with the wiring. If your motor is spinning to high-speed straightaway check that tacho connections, and if the problem persists after checking all those areas suspect the PCB or module.
check it out here
http://www.espares.co.uk/advice/0/2593/how-to-identify-an-error-code-on-a-bosch-neff-or-siemens-washing-machine-
