The system just stopped getting water through it. It it a plumbed unit. I took it apart, cleaned everything thoroughly and made sure that water was coming out of the water container freely. I also tried to get any beans out of the grinder that I could. Put it all back together. Still nothing. It feels like something is disconnected, but I can't figure out what that might be.
Can you please clarify the problem. Are you saying that coffee no longer comes out the spouts ?
Sounds like a problem similar to mine. I was getting a message to push in the water tank all the way, but it was fully seated. The coffee machine would go through the motions of creating a cup, but no water would be dispensed through the brew unit. The problem with this and likely the problem above is a clogged brew unit. I actually had to disassemble the brew unit to fully clean it, but once that was completed, the coffee machine worked fine again
I have this issue. seems the brew unit has no water coming out of the unit. can here it grind.
