LG SteamWasher WM2801H Front Load Logo
E
Ed Alfano Posted on Jun 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drum light stays on but washer won't power on
Jorgie the appliance guy
Level 3:
Top Expert:
  • LG Master 5,639 Answers
  • Posted on Jun 08, 2015
LG Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523793
Points
32630
Look for a blown fuse in panel or a bad door switch
Drum light stays on but washer won't power on - drum-light-stays-but-washer-power-nmtrxuhfc1nopxoeyhsrubgi-2-0.jpg
LG Tromm Dryer Won't Stay On!
Your motor might be weakened. As when you start is back does it come on if it does then we are looking at venting issue.
Oct 06, 2017 • Dryers
Ge Washer won't start, lights come on but won't stay on, what do I do?
Go online and search for brand and model number service manual. There are probably multiple things it could be, but the troubleshooting section should point you in the rite way.
Machine lights come on but the washer will not run
the drum is probably damaged or stuck inside the washer. or the belt the goes round the drum inside has probably snapped off.
My LG front-loading washer WM2501H drum light comes on at the end of the cycle and won't shut off. Additionally the control buttons cease functioning. If I unplug the machine and plug it back in, the...
I am having this same issue. I have to unplug and replug back in every wash. Very annoying. Especially because I am short and can't reach the plug without a step stool.
Power button stays depressed and does not start power menu. power is on, drum light is lit.
You will need to replace the control panel. The button is pressed in the down position and won't allow you to do anything else till this part is replaced.
2helpful
Door is closed and the light stays on. after a while non of the buttons will work any suggestions.
I have the same problem but my interior drum light stays on whether door is open or closed; in either case the control panel becomes in-operable after about five minutes. I unplug the machine for 5 to 20 minutes then plug it back in and it is powered "on" the moment I plug it in (i don't even have to push the power button). Then the light remains on but i am able to operate the control panel so i can do a load of clothes. Then if the machine sits idle for no more than five minutes, the control panel becomes in-operable again and the interior drum light stays on.
Any one have a clue???
2helpful
My wm2487hwma lg washer wont come on, drum light is on, but everthing else is out , no power. Unplugged washer and reset at fuse box, power came on, but same problem occurred.
I have an LG washer slightly different model but had the same problem. It washed the clothes but then the light would stay on but the washer would not turn back on. Remove door switch unplug wire that conects and check the connections. which requiered taking off the top and front of the washer. Mine were corroded after only 2 years. We cleaned the connection and it seems to be working fine again.
25helpful
4answers
Lg washing machine drum light stays on and wont let me turn the
Solution. Unplug the machine. Hold the power button for 10 seconds. Plug back in. Push the power button and the washer should turn on. Walk away leaving the machine on. When I did this, I came back to find the drum light off and machine would start on command now. Good luck.
28helpful
3answers
Drum light stays on and wont let me start it again. Its dead but has light.. I have to power down the entire house to get it to start again
I had the same problem. LG addressed the problems as follows:
1. Unplug the unit 2. Press and hold the power button for 10 seconds. 3. Plug the unit back in.
It WORKS!! It's like reseting your computer or alarm clock. You've got to kill the power and press and hold the on button while it's still unplugged.
Hope this works for you.
8helpful
2answers
LG WM2487H*M Drum light stays lit after each load is completed
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
