There is a small white light blinking below F in window.
SOURCE: new heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
SOURCE: malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
SOURCE: have heating pad model 818-7. blinking red light
I had this problem with a heating pad too. I tried turning it off, unplugging it, then plug it back in and see if the light is still blinking. If it's not, set it to the temp you want. My heating pad was very temperamental that way, it didn't want to be set before it was plugged in. I hope this works for you.
