Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Tom Smith Posted on Jun 05, 2015
Speed not changing in delicate mode fex831cso
waldofrog
Level 1:
  • Contributor 34 Answers
  • Posted on Jun 05, 2015
waldofrog
Contributor
Level 1:
Answers
34
Questions
0
Helped
24416
Points
82
The spin cycle is not going to change it is how strong the agitation is
And how hard it soins
  • waldofrog Jun 05, 2015
3helpful
2answers
Speed Queen Washer AWNE92. Agitate runs full speed on delicate cycles. Have tried unplugging and such. Any ideas?
Speed Queen AWN542 using the delicate cycle. Provides a brief
wash, 3 minute pause, quick agitation, then slow speed spin drain.
https://www.youtube.com/watch?v=VRyowST7tYo
2answers
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Why is the speed fast in delicate mode?
If you have high spinning in delicate cycle, then you probably need a new electronic module. It is a quite expensive spare part, so first check that this spinning is high by comparing it with a cycle for cotton / white coloured.
My sony walkman WM EX-190 is playing at low speed than normal. I changed the belt. bot still it is not playing at normal speed.
its maybe a failed speed ajustment or its slipped there is normally a tine whole on the back under the belt clip, press play and insert a small screw driver and turn u should find it speed up or slows down, if not its failed, but please be careful they are delicate anyhow
1helpful
I have a GE Washing/dryer Stackable machine combo. The speed maintain normal speed even with the Delicate Clothes option. How to trouble shoot? There is a Siebe Control that is connected to the timer Knob...
The speed change voltages are selected by the timer contacts. Try rotating your timer clockwise rapidly through several revolutions then select a delicate spin cycle and see if the speed is still too fast. If it is then the most likely suspect is the timer itself.
http://www.appliancepartspros.com/part_details.aspx?part_id=2045983
Model number used: WSM2780WAWWW
The timers are the same.
Thanks for using FixYa.
Kelly
Explanation of Wash Cycles
Sorry but you only have the one speed on this particular brand. Perm and short are just less time. The best thing to do is always use large water setting and less delicates in the load on a short cycle to compensate for the speed and protect your delicate fabrics.
Kenmore washer aggiates slower than when new. is
Usually, there are two agitator modes. A Normal ("Fast") mode, and a delicates ("Slow") mode. Put washer in 'delicates' cycle and see if the agitator slows down even further. If it stays at same speed as in perma press or 'normal' mode, then there is an open in the circuit betwixt the controller dial and the agitator control.
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
4helpful
2answers
Service Mode
System Diagnostics
SERVICE MODE
The service mode provides service personnel the
ability to verify the operation of the washing machine.
The service mode can be entered in the middle of
any wash cycle. While in the service mode, the
servicer can start a variety of special service tests.
Accessing Service Mode:
Pressing down the delicates and heavy soil keys for
3 seconds places the machine in the service mode.
Motor speed will be displayed when started. To exit
Service Mode, press delicates and heavy soil keys
for 3 seconds again.
Troubleshooting
December 2004 4 16025861
©2004 Maytag Services
Stage of
Wash Cycle
Advances To
Presoak End of Presoak
Wash Every 5 Minutes of
Wash Time
Spin/Drain Every Step of The
Spin Profile
Rinse End of Rinse
Speed Range Displayed
a) 0-99 rpm 0-99 (actual)
b) 100-999 rpm Speed / 10
Quick Service Cycle
While in service mode, pressing the delicates key
will start a quick service cycle. This will be a quick
check of all systems.
The following steps will be followed.
1. Energize the cold and bleach water valves. Fill to
Low level, then turn bleach and cold off.
2. Energize the hot and fabric softener water valves. Fill
to high level, then turn all valves off.
3. Lock the door.
4. Tumble using 7/3 tumble pattern for 12 sec.
5. Turn the drain on.
6. Spin to 800 RPM using default rates.
7. End spin and coast down.
8. Unlock the door when the RPM is zero.
9. Display a ‘PA’ (Passed) on continuously for 10 seconds
if no diagnostic codes were logged during this
test.
The up arrow if pressed will advance to the next step.
The right most dot will be turned on as an indication
of failure and stay on until quick service cycle test
has reached the end. Any diagnostic code logged
during this test will result in failure of the test, but will
not necessarily stop the test. While in quick service
cycle, the pressing of the hand wash will suspend
the machine at this step for 30 minutes until the
Hand Wash key is pressed again. All LED’s will
flash on and off while the cycle is suspended, or on
hold.
Motor Drive System
To check the system, check the board for proper
output to the motor control. Performing a board
output test does this. Then perform the Motor
Control Board Output Test.
Motor Control Board Output Test
1. Disconnect power to the washer.
2. Remove the front panel and pull the JP4 Connector
from the motor control board.
The following Quick Spin test steps are as follows:
1) Lock the door.
2) Spin to 350 rpm and hold for 6 seconds.
3) Spin to 550 rpm and hold for 6 seconds.
4) Spin to 600 rpm and hold for 6 seconds.
5) Spin to 650 rpm and hold for 6 seconds.
6) Spin to 800 rpm and hold for 6 seconds.
If the Spin key is pressed again during the Quick Spin
test, the current speed will be held indefinitely. Pressing
the Spin key again will allow the quick test to
proceed as listed above.
When the washer is in the Service Mode, the speed
will be displayed as a two digit number or a letter/
number.
Quick Spin Test
While in service mode, the pressing of spin key shall
start the washer in the quick spin mode.
3. Reconnect the washer power cord to supply
voltage. Make sure the door is closed.
4. Press delicates and heavy soil keys for 3 seconds
to activate Service Mode.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
