Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing.
Check the screen that filter debris, If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If you find nothing the problem is definitely from the water inlet valve
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
