Https://support.t-mobile.com/thread/61368
if the same is happening to u as the user says in the above link, hope u will get help from the website. :)
SOURCE: my alcatel fierce won't turn on
I think, ur phone has no problem, problem with ur phone\'s battery, check battery\'s point to touch ur tongue with those points if u feel something, like very little electric, on ur tongue its means ur battery is good, but u don\'t feel anything on ur tongue it means ur battery no more, or has no power to boot ur phone scratch the golden points of the battery by pin or needle for remove the carbon on the points if u phone didn\'t power on , replace the battery....
I don't know if it can be done. But when a phone (or any electronic device with a battery) not want to power up. I should always check if the battery is charged, and if the contacts from the battery and in the device are clean and shiny and not bent.
Then if possible to come close to the switch look if the switch is clean and nothing is wrong there.
SOURCE: My Alcatel one touch fierce head phone won't turn
Do you mean a bluetooth head set?Release the headset from the phoneby turning bluetooth off. Attempt shutdown of Bluetooth headset Ten re-pair the two. -good luck
First is the battery ok and fully charged. try and switch it on while hooked to the charger, you may have to hold the button down for a few seconds . if it comes to life now the battery is at fault. If nothing have the switch checked out.
SOURCE: Is the alcatel one touch fierce 2 compatible with Samsung kies ?
Why looking for Kies when Alcatel already have a softwear designed to work with its phones?
here is the link to download it:
ALCATEL ONETOUCH Support Android Corner
