Tablets & eReaders Logo
J
Joyce Smith Posted on May 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset my Z Pad?
I need to reset my Z Pad to factory settings
Mike M
Level 3:
  • Tablets & eR... Master 3,349 Answers
  • Posted on May 24, 2015
 Mike M
Level 3:
Answers
3349
Questions
0
Helped
686180
Points
16707
How do I do a factory reset when it only has reboot or recovery setting on the asus
You can do a factory reset via the settings menu. Look for a 'Backup and Reset' entry.
I put my pin # on my new pad, now it wont open, how can i get my pad opened again
Factory reset! Press power for about 30seconds so it ends up off! Then press power and volume+ buttons together until reset page appears, select factory reset!
2answers
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
How to reset pendo pad
Go to settings and scroll till you find reboot your device to factory settings. Or "backup and reset" Under "Accounts" in your settings. Then click on "backup and reset." Every tablet and cell are somewhat different. Be sure to read your manual, very easy to do when you are familiar with your device.
I want to clean my eepad prior or giving to my granddaughter
The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
Too many pattern attempts
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
1helpful
I HAVE A TBS "T-PAD" THAT I NEED "DETAILED" INSTRUCTIONS ON HOW TO FACTORY RESET OR HARD RESET. I HAVE NO MONEY TO TAKE IT TO A REPAIR SHOP , HELP ME!!!
you should be able to go into you settings and find the factory reset there and before reseting it check to see if there is a back up and restore box if there is click it so when you turn the tablet back on you should be able to restore all of your apps and music content back.
My Asus memo pad 7 will not download paid apps
Have you tried doing a factory reset? Try doing this under the settings menu, which should clear up any issues & then you can try to download your desired apps again.
How do u master clear a a pad tablet
If you mean an iPad by "a pad tablet", then completely clearing it is very simple:
  1. Open up Preferences
  2. Select 'General'
  3. Select 'Reset'
  4. Tap 'Erase all content and Settings
This will completely wipe the iPad, returning it to it's factory state.
Hope that helps!
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
