Jumper tested the starter battery to starter direct.tractor started tractor cut grass 15 min.and it quit.replaced 15 amp fuse now no electricity at plug and will not key start
SOURCE: when I mow with my 42
Hello:
This is Usually Caused by Worn Blades or a Bad Mandral/Blade Spindle Bearing.
Remove the Deck from Under the Mower.
Remove the Deck Belt.
Check the Mandrals/Blade Spindles for Bad Bearings. Do the Sound Rough when you Spin the Pulleys by Hand? Can you Move the Mandralls/Blade Spindles from Side to Side? If Yes, then the Bearing s Require Replacing.
Look At the Tips of the Cutting Edge of the Blades. You will Se the Tips are Rounded and Not Square. This Condition will cause the Strip in the Center of the Deck.
I have Just Joined this Site. If you Send me the Model Numbers Off the Unit, I can Assist you Better.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
check the wires from the back of the ignition and also the small wire that connects to the starter, if you get a 12v test light check each wire individually by holding the test light on the wire and have somebody turn the key, the test light should come on if the power is going through the wire.
If there is no power the ignition may need replacing
SOURCE: tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
SOURCE: My craftsman LT 1000 lawn tractor will not start.
No you dont need a new starter, the gear is stuck.
Try WD40 and gently free it with a screwdriver.
SOURCE: 16 hp lawn tractor won't start; replaced battery
starter cylinoid is bad i almost bet
Testimonial: "Fixed it in now time. Thanks for your help."
