Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset
Performing a factory reset via settings:
The most convenient way to do a factory reset is via the phone settings.
From the Home screen, press MENU, then tap Settings.
Scroll down the screen, and then tap Privacy > Factory data reset.
On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
Performing a factory reset using phone buttons:
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.Press VOLUME UP to start the factory reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
