Moved from Cars and Trucks category to Snapper Ride on Mower.
Breaking or falling off is a pulley or pulley alignment issue, or a tensioner issue. Belts are just ordered by make and model specs. Don't sweat the details on length.
1) Brake - inside the frame, next to the brake pedal
2) DECK/PTO - underneath the fuel tank, at the base of the dash assembly
3) SEAT - underneath seat
4) REVERSE - on top of the transmission
check for grass and other material that is wrapped around the shaft above the disc and acting like a brake
when it is clear check for failing bearings on the disc shaft
Michael, Check the attached links, 1st link is snapper where you can get info from support,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Tractor Riding Lawn Mower Products Snapper Mowers Tractors
provide it is a 3317524BVE then most likely it is a sheared or missing roll pin at the base of the steering wheel or the weld at tie rod has broken loose.
