I had a wine glass break in the washer, and a small shard of glass got stuck in the drain pump. Pulled the unit out, put it on its side and took the drain pump assembly apart. Removed the glass shard and its working well again.
Water inlet valve is not working properly. either not letting water through the valve the first time and now it is sticking open and letting water over fill. Replace water inlet valve.
Thank you Sandy for your suggestion. It was the right fix for us. My daughter had opened the door 6 minutes before the end of the cycle (which I didn't know) and next day when I wanted to do laundry it showed an error. We were going crazy because we couldn't make it work. I read your comment (to tell you the truth with no hope) but it worked!!! I'm so happy didn't have to call the repair man which would have charged more than $100 to see it. Thank you!
We found a way to reset the computer and solved the problem.
1. Press and hold pause turn off machine and turn back on holding pause all the while.
2. This should reset the computer. All lights will light up on LCD display.
3. Release pause button. Turn off machine, turn back on and begin a new wash cycle.
woo hoo!
I am not aware of an LG code 1F. But there is an error code "1E"
After you double check that the water valve is open that feeds the dishwasher, focus on the inlet valve (solenoid)
As you remove the inlet valve, if you see the screen is filled with gunk, clean it and retest.
Good Luck!
