I removed the filter cover & the filter. I now need to remove the front panel which after removing the single screw, won't come off.
Sorry it took so long for me to answer this question for you, So simple but I admit it can be a pain to remove on your 1st try, but trust me it's easy. Once you remove that 1 screw, push on the metal cover RIGHT AGAINST TO THE FRONT PLASTIC COVER while pulling that side of the plastic front outward. You should hear it snap, that's the front cover releasing from the metal cover. Do that on the left & right sides, then put your hand on the bottom edge of the plastic front while pulling downward, then just tilt it up like a hinge. To put it back on, start by attaching cover at the top till it catches, then just lower front cover down against the unit. You'll need to push in the sides of the metal cover right next to the plastic front till you hear it snap into place. That's it!
I hope that helps you! Have a Great Day!
Press around the panel edges while pulling back. There are probably plastic clip locks that need to be depressed to unlock. Flex carefully, taking care not to break the plastic cover.
