Shopnbc Zeki 7" Multi-TouchTablet Logo
Nathaniel Forcelle Posted on May 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is stuck at the Zeki logo boot screen and the power & volume button button to reset and also holding the reset button dose not work.
Jena Ulmer
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 14, 2019
Jena Ulmer
Contributor
Level 1:
Answers
Questions
0
Helped
174
Points
You may have to hold it down longer.. I noticed with mine it did that also. But it did reboot after it
Aden Gittings
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on May 17, 2015
Aden Gittings
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
4045
Points
88
I agree try running it dead flat then charge.
Gary Gemmell
Level 2:
An expert that gotĀ 10 achievements.
Sergeant:
  • Expert 261 Answers
  • Posted on May 12, 2015
 Gary Gemmell
Expert
Level 2:
Sergeant:
Answers
261
Questions
0
Helped
65203
Points
527
Let it run the battery down then recharge and start but it sounds like the boot block and os is hosed in which case its a goner.
It can be volume up or volume down after pressing the power button. Which one did you try - try both. Did you try pressing the reset hole with a pin?
2answers
Samsung Galaxy 3 Tablet, after charging it over night, when trying to power it on today, it goes to a samsung logo and freezes.
try to set it back to factory.
press and hold the "Volume Up", "Home", and "Power" buttons.
Release the buttons when you see the recovery screen and the Samsung logo.
Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...
On the next screen, press "Volume Up" to continue.
How do i reset my zeki tablet when the factory reset wont work
on Zeki Tablet you had to hold both the "Reset" button and the "volume up" button at the same time for about 15-20 seconds it than boots into Safe Mode which you can select a full factory reset. NOT VOLUME DOWN.
If this fails, 1 888 999 4215 is Zeki support. If in warranty, tell them of failure of factory reset. They may request it be sent to them.
2answers
I turn on zeki tablet and it possible up that everything stopped working and it won't leave the camera. How do I fix this
You can reset the Zeki by Powering off. Then at the same time press the volume up button and the power on button, hold them until the Android splash screen pops up.
1helpful
My zeki stuck on the zeki logo
You need to do a factory reset!
  1. Make sure your tablet has a full charge
  2. Press and hold the Volume - button and tap the Reset button
    (The reset button is located between the HDMI and USB ports)
  3. Continue holding the Volume - button until the boot screen appears
  4. Release the Volume - button
  5. Use the volume controls to navigate to "Wipe data/Factory reset"
  6. Press the power button to select
  7. Navigate to "Delete all user data"
  8. Press the power button to select
Your tablet will take several minutes to reboot to a factory default setting.
1helpful
2answers
How to reset a zeki tablet password
Hello there,
From the Zeki website it says do this.
If you have set the screen lock to a password or pin code, and have forgotten the code; you will need to reset you tablet to factory default setting.
  7. Navigate to "Delete all user date"
Your table will take several minutes to reboot to a factory default setting.
Hop this helps you friend. :)
I have a zeki tablet that won't load, wondering if anybody here can help me?
I'm assuming it is the Zeki 8" TBDG874B. What I would do to get it of the flashy Android logo is hold down the volume button on the minus (-) side and get a small pin or needle to tap the reset. While holding the volume it will reset, then tap the power button still holding volume it will bring up a list. Do a factory reset (you lose all data but that's what I would to do to be on the safe side).
5helpful
2answers
Tmax tablet 9 screen freezes booting up
You need to do a factory reset by holding down the power and the volume (-) down button at the same time until u see a black screen with Command prompts.. After this use the volume up and down buttons to stroll up and down and the power button to select.. Go down to data factory reset and press select then select yes.. And your tablet should reset itself.. This May or may not work on the first try.. Please wait at lease 5 minutes for it to boot up because it will take a while to boot after this so don't get all frustrated. If it's still stuck at the go logo just go back to step 1 and repeat.. This is what I did for my tmax 9 tablet when it was stuck at the go logo.. It didn't work the first ten for me but for the 2nd factory wipe it did the trick..
88helpful
6answers
Tmax 9 tablet stuck on boot screen
  1. Shut off tablet
  2. press the volume minus button and the power button @ start up
  3. tmax logo shows up and then a android menu
  4. factory reset
  5. Once complete, reboot
  6. wait 4-5minute... tablet works again
7" supersonic tablet is stuck on the opening android screen and will not boot. The tablet's battery power went empty during the last use and was fully charged afterward.
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
How do I unlock it once code is forgotten?
Just got off the phone with support!
1. battery must be fully charged first.
2. power on the device.
3. locate and hold the volume down button while using a safety pin
press and hold the reset in until it starts booting, release the reset
button and hold the volume down button for 10 seconds then release.
4. if you are not prompted to factory restore, repeat step 3 but this time
hold volume button for 15 seconds after booting.
when you get to the restore prompt you must use the volume + or -
to navigate and the power button to select. hope this helps!
Top Shopnbc Tablets & eReaders Experts
ADMIN Eric
ADMIN Eric
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a Shopnbc Tablet and eReader Expert? Answer questions, earn points and help others
