It won't stay on long enough to check menu and there is a dvd stuck inside and it won't eject it either.
SOURCE: rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
SOURCE: have a 52 inch rca
replace the flyback, very easy repair. You need flyback 259296 you can getone at the following link with free step by step instructions with pictures. heres the link read their reviews.
http://servicemanuals.vstore.ca/
SOURCE: MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
SOURCE: rca rear projection tv has sound but no picture. clicking noise coming from the back.
replace the lamp.
